Scale font size automatically
tobias.bjornstad
tobias.bjornstad
Hi, is there any way to scale font size according to the ammount of characters in the textfield?
Working on a titleblock and would like the sheet number to scale down in fontsize when it contains more than two digits, so our sheets look balanced and tidier through all stages of planning. We usually start the concept designs with numbers 01-50 and finished designs to H800-B and so on. Attached two screens to illlustrate the problem.
Is there a way to "code" so that the label adjusts the type its using based on number of characters, or if the text goes beyond the text box border?
"Code" it?   I don't think so. Those Labels are populated in the Project environment - not the Titleblock Family.  What about Titleblock Family TYPES with various sizes?
tobias.bjornstad
Would that require the user to choose the ffamily type manually when text overlaps the edges? How do i set that up? Thanks for the reply
Just create Titleblock Family Types with different sizes and swap out the Type used on the Sheet when need be.
