Same view/section on multiple sheets
emmanuelbee
emmanuelbee
Is it possible to have the same view on multiple sheets without having to rename the on of the view. At the moment if you have copies of the same view you can't make place them on different sheets if they both have the same name. You have to rename one of them, is there a way round this?
ennujozlagam
hello, not possible at the moment in Revit. thanks
Avaris.
You have to rename, I would advice to make a duplicate as dependent, that way the views will be always the same.
