Same section name for different plans
jianlin.sunXCKBF
jianlin.sunXCKBF
Hi, if I have a section (A-A) on building A and another section (A-A, same location) on building B, it would appear that I have to change view name (not title on sheet) to something different in order to show them both on the plans. This creates a problem because section A-A indicates the same location for both buildings. Is there a workaround for this issue?asdfad.png
Thanks!
ennujozlagam
not possible, same section name in the same file, need to rename the other one. thanks
RobDraw
Not good drafting either. Different sections with the same name could lead to confusion.
I suggest working the building designation into the section name.
Rob
jianlin.sunXCKBF
Unfortunately my hands are tied on this part of Europe.
RobDraw
I'm not familiar with that. Standards shouldn't interfere with good drafting practices, IMVHO.
Time for a workaround or a different approach to the project.
Rob
dferreira-blackwell
If both sections show the same detail then you can use ref. section. this will have the same name but also leads to the same section.
Rename one, right click on the number and insert an Unicode character.
