Same element used in different nested families one does not schedule
claudiakopietz
Message 1 of 10
claudiakopietz
Need some help on this one.
We have 2 different types of bathrooms in a project. Both were created as nested families so we could repeat in our model and quickly schedule the information. However, all elements in that nested families have the Shared ticked on one of the elements that is the toilet will show on the schedule of bathroom type one but not on the schedule of bathroom type 2.
I have searched for an answer but so far no luck with it.
Anyone has have a similar issue and how has been solved?
many thanks Claudia
Replies (9)
Message 2 of 10
RDAOU
@claudiakopietz
Maybe if you share what you have it would be easier to check and tell you what exactly is wrong
  • Are all the components shared in both families?
  • Any filters in the schedule?
You could do what you are doing (different toilet/bathroom) using Model Groups and key schedules
Message 3 of 10
claudiakopietz
unfortunately, I can't share the families here as they are too big.
let me try to breakdown this way
we have Bathroom 1(B1-I) and Bathroom 2 (B4-I).
Both use the same exactly families inside
all families have shared as well as the nested families.
bathroom 1 schedules all elements inside it
bathroom 2 does not schedule the toilet and the door hook. and they are the same elements!
image 01 attached I have highlighted the elements
image 2 is for the schedule showing the difference. I have highlighted the elements that are missing in the B4-I toilet.
the schedule is the same so they should be showing fine.
By experience I would not do that as a nested family either but, it was the route they decided to follow and is too late to start fresh again. I just need a solution for it.
hope that is more clear.
many thanks in advance 🙂
Message 4 of 10
claudiakopietz
forgot the second image.
Message 5 of 10
RDAOU
@claudiakopietz
Well the only thing I can think of without seeing the family B4-I is that the Toilet seat and the paper holder you nested into that one were not shared
  1. Close all open fmailies
  2. Open the Family B4-I
  3. Select and edit the Toilet seat
  4. Make sure it is checked as shared
  5. If it is not (which might have been overlooked), make is shared >> reload to B4-I and reload B4-I to model
Message 6 of 10
claudiakopietz
I wish you were right but it was the first thing I checked. and the family B4-I is shared. 😞
I just purge the families so you will be able to have a look at it.
find attached 🙂
C
Message 7 of 10
RDAOU
@claudiakopietz
You have an issue with the room calculation point of the fixtures....when they fall on the room boundary they are not being scheduled inside that room...Meaning if you are sorting by Room Name for example, these fixtures will not appear under that room
  1. Open the Fixtures (all best) and enable Room Calculation point
  2. Then Drag it to the middle where it will always fall in the space/room
Message 8 of 10
claudiakopietz
thanks for this...but why is affecting just the toilet and not the other items?
could you share a bit more knowledge on it, please?
Cheers,
C
Message 9 of 10
RDAOU
@claudiakopietz
It is affected depending where the ORIGIN of the fixture falls with respect to the Room Boundary...when the room calculation point is disabled, the fixture gets scheduled into the adjacent room if the origin falls outside the room. therefore, when you enable the room calculation then you kinda force the fixture to schedule in a specific view when its origin falls at the border
Since the fixtures you used are shared, you need to set the room Calculation point for each to ensure they all get scheduled in the right room. See  the following link for more info about the room calculation point and how to adjust it.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
See how yours schedule in room 2 and 3? although they are in B4-I
Message 10 of 10
claudiakopietz
That did the trick thank you so much for looking into it 🙂
and thanks for sharing this link I will have a look.
Best,
Claudia
