Room tags in linked architectural model aren’t appearing in furniture schedule.
tyler.r.stinsonJ2FGE
Hi, I have a similar issue from a client and want to make sure I am answering them correctly. Their issue is that they have a linked Revit file (in Revit 2021), and the client wants to add room tags to the rooms in the linked file. I should note that the file they gave me does not seem to be linked (as the save to central symbol is not highlighted - but greyed out - making me think they detached from central). They want to add Room tags in the linked Architectural Model but in the furniture schedule the tags are NOT appearing. Is there a way to fix this?
RDAOU
@tyler.r.stinsonJ2FGE
The sync icon being grayed out implies only that the Model you have in-hand is not workshared. There are no issues in using non-workshared models as links
As for the room name and room number...If you have checked the "Include Elements from Link" in the schedule the the furniture, their room number and room name should show in schedule if the furniture is aware of the room it is placed in.
  • Is the room calculation point in the furniture families checked?
RDAOU
Another thing to check is the level which the furniture is hosted on and that which the Room is on
  1.  a section view >> Visibility graphics and enable rooms Fill and Reference
  2. check if the furniture actually fall inside the room
If the room base is at the FFL level while the calculation point is disabled and the furniture is hosted on the Top of Slab Level , the Furniture would be considered outside the room
ie: you would then solve it as follows
  • either re-host the furniture on the same level of the rooms
  • or change the room base level to match the level of the Furniture
  • or Work with the room calculation point mentioned in previous reply
I tried using that button and this is what appears after. The Type Marks are showing up but the room: Number is still not. It should be associated with the chairs for example.
I am attaching another screenshot.
RDAOU
Did you read the above 2 replies? The Include elements from link is for your client when they link the file...you first need to make sure that the furniture schedule correct
See the steps described in the previous replies and watch the GIF in reply 3
  • Reply Number 2 : Enable and adjust room calculation point in the furniture family
  • Reply Number 3 : How to check discrepancy in host levels of the room and the families
See example below...(same from the GIF posted in reply 3)
  • Room is on Level 1
  • while the Sofas/Furniture are hosted on Level 1 Living
  • Room Name and Room Number does not show in schedule unless
    1. Enable and adjust Room Calculation Point in the Sofas
    2. Or Change the Room host to Level 1 - Living
Thanks - I'll take a look into these steps and get back to you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
