RVT 2022 - objects won't rotate
keenanK8NG6
Message 1 of 43
keenanK8NG6
Just as it sounds, objects placed into a Revit model can not be rotated. (For example, a chair placed on a floor, then rotated into position)
There's no error displayed, the object simply just doesn't rotate after either graphically drawing the rotation angle or entering in the angle.
Objects aren't pinned or locked to some plane
Have tried creating new models
Have tried using different templates
wtf is going on here..
Revit 2022.1
erlapped with an update to 2022'
Accepted solutions (3)
Replies (42)
Message 41 of 43
Alfredo_Medina
Sure I do. But I have already updated the models of that project to 2023, and the issue was solved.
The issue was not only the rotate tool, but the align tool as well, with the same common elements, chairs, desks...
Message 42 of 43
So you did but now you don't.  Sorry but it doesn't help.
Message 43 of 43
Alfredo_Medina
Sorry. Even if I had the model, I was not going to upload it here, if that´s what you´re going to ask. It is a project that I´m working on, which I see no reason for uploading to a forum.
