rpc trees base plate
gregoriosaura
gregoriosaura
hi everybody,
Would anyone know please if it is possible to remove the horrible 'base plate' to rpc trees' placeholders supplied with Revit 2017 ?
Thanks in advance!
What base plate?  Can you post a screenshot of what you want to remove?
Sahay_R
I was able to get rid of it in the Ref Level view - I moved it to a new subcategory and turned it off. So in plan the family does not look quite as awful.
The Base Plate that you talk about is something that comes along with the RPC family template.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
rimacoca
Hi @gregoriosaura
I do not think it's possible
You can assign a negative offset to disappear the arrow, or turn off the rcp by category or by filter.
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
rimacoca
Hi @gregoriosaura
I remember now you can make also a second approach.
Check the sample  file attached you can  turn off and turn on the RPC shape and show a different conceptual form.
Submitted ideas
gregoriosaura
Thanks  rimacoca , it could be a solution, however I should remake all rcp types, and the final 3D without rcp is not very reassuring 🙂
