- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Revit 2015 LT and all the sudden (after installing Revit 2018 - which I later uninstalled) my plantings are not showing up in realistic 3D views. They do show up in the plan views and if I override the visibility graphics and make them transparent, I can see outlines of them in the 3D view. I have searched the forum and nothing seems to be working. I uninstalled all versions of Revit and their libraries and reinstalled 2015 and still the same issue. I installed Archvision dashboard and ran/installed the plug-in. Still nothing. I checked the C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2015\assetlibrary_base.fbm\RPCs path and the .rpc files are all there....but still nothing showing in the 3D realistic view. When I try to edit the RPC planting family and click on the render appearance to try and select the correct image, the render appearance library window is blank. I checked windows programs and all libraries are installed (medium, low, etc). What do I need to do??
