Roundup total, not itemized
jagostinho74
Message 1 of 8
jagostinho74
How to get a roundup column which picks up on the calculated total displayed and not rounding up each area individually first and them add them all up.
In the example below, I want to be able to roundup the 8.1m2 into 9 m2, not rounding up each 4.1m2 into 5m2 and show 10m2
Thank you
J
Assistant BIM/CAD Manager
Manchester, UK
Replies (7)
Message 2 of 8
Kimtaurus
Revit always calculates using the original individual values.
So it's not using the total of the rooms to calculate with, but the values per instance.
I doubt that what you want can be achieve in Revit, at least not automatically, maybe with Dynamo.
Or export your schedule to Excel.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
jagostinho74
Thank you. Was trying to check if there was a workaround for this.
Manchester, UK
Message 4 of 8
It's doable.  See attached.
Message 5 of 8
jagostinho74
@ToanDN. Thanks.
That schedule is itemized.
How about for grouped values? See my images above.
Manchester, UK
Message 6 of 8
Still works.
Message 7 of 8
jagostinho74
I need it to roundup in a way so that if total grouped area = 8.1m2 it rounds to 9.0m2
Manchester, UK
Message 8 of 8
jagostinho74
Manchester, UK
