Rounded Edge Shape (Conceptual Mass)
8 REPLIES 8
Message 1 of 9
1509 Views, 8 Replies
I was wondering how I would approach rounding out the edges of the shape attached:
Round Edge 1Round Edge 1Round Edge 2Round Edge 2
General Shape:
General ShapeGeneral Shape
I tried a bunch of different ways, but I just couldn't figure it out in the end. (Using voids, using reference lines + profile)
I'm hoping to not go outside of Revit to round out those edges, but if it's not possible in Revit then outside of Revit is ok.
I've attached the .rfa of the shape.  Any help or thoughts appreciated, thanks!
Labels (5)
8 REPLIES 8
Message 2 of 9
constantin.stroescu
when you create the basic curve ,take care to use Tangent to Arc (as in my first screencast) or use a Spline (as in my second screencast ) so to have curve continuity:
1
https://knowledge.autodesk.com/community/screencast/6abbf13e-1d43-41bd-9ca4-2551f3fd7049
2
https://knowledge.autodesk.com/community/screencast/210af551-8e80-46b9-b5b6-eb608f97edf4
Constantin Stroescu
Message 3 of 9
in reply to: constantin.stroescu
Hi Constantin,
Thank you so much for the videos!  You've provided me with some really good tips.
I just tried the method you did with video #1.  There are some parts of the shape that remains flat.  What would  your approach be to rounding out the edges for when the flat part meets with an angled part of the shape?
Reference below:
Round out edgesRound out edges
Some background on the shape:  I was trying to create something that would follow a stair path, so some parts are angled while some parts are flat.  But I was hoping to make the transition from flat to angled smoother by rounding out where they meet.
I was able to round out some parts with a void form, but it's not very accurate because of how the shape curves:
Rounded EdgeRounded Edge
Here's what the void form looks like (Used a reference point and used the plane to create a void profile)
Rounded Edge MethodRounded Edge Method
But since the shape curves, using fillet arc doesn't work when creating the profile, so I approximate the shape.  Approximating the shape causes the issue below:
Void IssuesVoid Issues
Thank you again for your videos!
Message 4 of 9
Why don't you built that shape by creating a form from a smooth curve instead of fixing the crooked shape after the fact?
Message 5 of 9
in reply to: ToanDN
Hi Toan,
Thanks for the reply!  I'm not too sure what you mean.  Something like below?
#1 Make the profile first and then twist the form:
Start with a curved profileStart with a curved profile
#2: Start with a curvy form and cut out the shape I want using void forms:
Start with a curved columnStart with a curved column
Thanks!
Message 6 of 9
Sorry I think I was unclear about what I was trying to model.
I was trying to find a way to make the transition from flat to angled be rounded. I'm having trouble figuring it out when it's a spiraling shape with each segment having a different radius.
Each segment has a different radiusEach segment has a different radius
Thanks!
Message 7 of 9
Message 8 of 9
in reply to: ToanDN
Ah I see! Thank you!
I tried something similar to that, but I used multiple profiles:
Profiles following a curved pathProfiles following a curved path
I wasn't able to use the sample in the image above because I couldn't figure out how to set the radius of the rounded 'edge'
Hoping to control radius of roundingHoping to control radius of rounding
I was hoping for something closer to the red + green outline.
Is this similar to what you were suggesting?  Or were you thinking of using only one profile and then using another void profile to cut the bottom and top parts?
Thanks!
Message 9 of 9
Then draw the path using lines and fillet between them.
