- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Question about how the align function in Revit works compared to Fusion 360.
In Fusion 360 I can align to a plane and a face equally and the software will rotate my part so that the face contacts properly.
In Revit, it seems to attempt to perform the alignment but the part doesn't actually rotate to align the face as intended if the place being aligned to is angled and the part is not. It solely moves the part on a vertical or horizontal axis.
In the above case, it simply aligns to the edge of the part to the closest endpoint of the reference plane without rotating the part.
I have tried detaching the part from its plane prior to alignment without luck and I know that I could simply draw the part directly on a workplane.
I am just wondering if there is any functionality that I could use to get me closer to how Fusion 360 handles alignment?
