Rotate the pat
Rotate the pat
Message 1 of 8
Rotate the pat
I can I rotate the pat?
i know there is a program that is an add-in of revit but donìt remeber name
.rvt attached.
 Thank's
Replies (7)
Message 2 of 8
MostafaElashmawy
Do you mean this one:
https://apps.autodesk.com/RVT/en/Detail/Index?id=8108376445166465656&appLang=en&os=Win64
Mostafa Elashmawy
Message 3 of 8
Ilic.Andrej
Instead of making a drafting pattern, make a model pattern. Then, all you have to do is hover an element that has a material applied to it, hit tab and select one of the pattern lines. Rotate it in any direction.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 4 of 8
@Ilic.Andrej  can't click on model
Message 5 of 8
You might be able to convert it to a Model Pattern by opening the source *.pat and changing  ;%TYPE=DRAFTING to ;%TYPE=MODEL
...and then re-creating the Pattern in Revit with the revised *.pat file.  Or, just make a new Revit Pattern from it.
Message 6 of 8
@barthbradley  a screenshot please.
However don't undrestand why I can't charge the family of panel correct.
I change the direction of pat and than when upload in project is the same in the wrong direction.
The panel of railing should be vertical
Message 7 of 8
You need to assign Baluster Material Property to a Named Parameter in the Family and then reload it into the Project, andd then assign a Project Material to that Named Parameter.
Message 8 of 8
You also need to use MODEL Patterns -- not DRAFTING Patterns.  You'll be so much happier. I promise.  Google for "Wood Grain" MODEL Hatch Patterns.  There's a bunch of different ones out there to choose from.  Here's one site with a few.
http://cad-corner.com/Hatch%20Patterns/
