Rotate Section... bug?
spowers5NTA4
Message 1 of 12
spowers5NTA4
Just curious if anyone else is experiencing this... when I rotate a Building Section that I have created, it resets the view to defaults and sometimes even renames it back to "Section 1". In the event that it renames the view, it removes the tab and I have right click and "Go to View" again. When I get into the view I have to reset the view template and adjust it to how it was.
Basically, rotating a section cut now kicks you back to square one as if you'd just created the view. Very frustrating.
Replies (11)
Message 2 of 12
Do you have Copy box ticked when you rotate the section line?
Message 3 of 12
spowers5NTA4
I do not.
Message 4 of 12
If you are talking about the view template then yes, when you copy or rotate a section line with Disjoin box checked, Revit removes the assigned view template from the view.  If you want to retain the view template after rotation then untick Disjoin box.
Message 5 of 12
NikAndjam
have the same exact problem, started in 2023, rotate a section and revit renames it and removes the view template, I just noticed the same behavior with scope boxes, rotate a scope box and it gets renamed, very annoying
Message 6 of 12
RSomppi
Did you try the suggested solution to the same exact problem?
Message 7 of 12
NikAndjam
wow, you are so helpful, why didn't I think of trying a few things before posting here, I must be an idiot
Message 8 of 12
RSomppi
When you are done trying, let us know what worked or didn't work for you.
Message 9 of 12
NikAndjam
no
Message 10 of 12
NikAndjam
this works
Message 11 of 12
roberts_gajevskisH3HZ7
Select the section and when you're using the command ''Rotate'' make sure ''Disjoin'' option is unselected.
Message 12 of 12
jason_huddlestonVH79A
Community Visitor
Community Visitor
I had this same issue thanks for showing the Disjoin button i didnt know what it did
