Room Tag mask visible not requested
6 REPLIES 6
mzmaso90
253 Views, 6 Replies
Hello guys, I don't find where to modify settings in this tag, because I would like to hide the mask boundary, but still reamins even looking through all its parameters of texts, they don't have border masks on and in visibility settings nothing is like hided in the family view, so I thin it belongs to the number of local from the older version of the family, thant's is the standard one from Revit. Any tips?
6 REPLIES 6
Alfredo_Medina
in reply to: mzmaso90
To modify that property, open the tag family. Click on one of the labels > Edit type > find the Background property, which determines if the text is transparent or opaque. Then load the family into the project.
mzmaso90
in reply to: Alfredo_Medina
Every text labels is set on transparent with no border mask
Edit the family and turn on Annotations category to see the box in order to delete it.
Alfredo_Medina
When you use the word "mask" you confuse me. Are you referring just to the rectangle around the text?
mzmaso90
Yes, s my fault in translation. I should have called it just "show border"
mzmaso90
Thank you Toan, always in right place at the right moment. Thank you also Alfredo for your time.!
