Room Schedule with Colour Key
shefypattambi
Message 1 of 10
shefypattambi
How can I create a room schedule with color key as shown in the pic ?
Accepted solutions (3)
Replies (9)
Message 2 of 10
Capture an image of the color and insert the image into the Image Parameter Field of the Schedule.
Message 3 of 10
RevitRx
Conditional formatting of those blank cells is an alternative, but not a two click solution you're looking for unfortunately. Also look at changing the size and orientation of the color scheme legend and place it "next" to the schedule.
www.RevitRx.com
Message 4 of 10
If you only have two colors then Conditional Format works.  More than two then you need to capture images and use the Image field.
Message 5 of 10
shefypattambi
Hi @barthbradley , @ToanDN  @RevitRx ,
Any idea how did he calculate the percentage  for each room ?
Message 6 of 10
Add a calculated value parameter and choose percentage instead of formula.
Message 7 of 10
Huh?  In order to write the forumla, you would need to divide the Room Area by the Gross Area.  I suspect the creator inputted the gross area as a number into the "Percentage" Calculated Parameter formula (e.g. =Area/24).
Message 8 of 10
shefypattambi
Me too stuck at this point. it seems to me that he manually put the total area in the calculated parameter formula as you said.
Message 9 of 10
No he did not manually input anything. Use the Percentage option in the calculated value parameter, do not use any formula.
Message 10 of 10
shefypattambi
Wow....that was a cool tip...Heart
