Room computational height error
Hello
I am having problems to adjust the computational height, it seems that the instance parameters are locked
Revit_Whisperer
That information in the room object properties is read only based on information associated to the room element...as the room changes size or height it automatically updates.
You can however change the computation height of the level if you want, or adjust the top and bottom constraints of the room if you prefer.
Computation Height
thank you for answer me,
Well I am trying to change the computational height, but I´ve searched everywhere, where did I do this?
Revit_Whisperer
There is a link in my first post about how to adjust the computation height 😃
Basically if you go to a section view, select the level you want to change it on, go to instance properties of the level (under Dimension category) and adjust as needed.
Thank you very much!
