room color scheme not showing
adel.alyasin
adel.alyasin
Hi
I made a (template project ) to set my rooms in It, and I linked  my Revit model in It , but when i try to make a view with color scheme based on room-number It doesn't show properly because the material has a solid fill background
how can I make Revit show the (room color scheme) properly without changing the material in my model
Thanks  🙂
Accepted solutions (4)
Replies (13)
rxi.gg
Hide the pattern of the floors
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
adel.alyasin
Hi Thanks for reviewing my problem
I found a solution for It
You can select the floor (useing  Tab) and then override by category and set trancparency to 40% or something
rxi.gg
You can do it that way or implemented in the template, by hiding floor patterns or putting transparency. I'm glad you found a solution
adel.alyasin
Yes I agree but now i am facing another problem wich is now I see some elements under my floor so now i have to adjust my view range
there should be an easer way to do this
rxi.gg
Try putting a normal view range (lower level =floor level) and directly hide floors
adel.alyasin
Yes as i told you
It works but there shloud be an easer way to do it
I do not understand why would it not work
why room color scheme does not override the material background color
I think autodesk should fix this (room color scheme is above te floor itself) why does not revit color them (the rooms) if there is solid fill patern behind It
adel.alyasin
My view range is at 0 so it is at the top of my floor but I still see the botom of my stairs so there should be another way to do this
adel.alyasin
see the screenshot
I would not make the floor transparent, but VG and turn off surface pattern of Floors category.
adel.alyasin
how can I do It?
@adel.alyasin wrote:
how can I do It?
Visibility/Graphics Overrides (VG).
adel.alyasin
Thanks it worked
awrightHCA83
Community Visitor
Community Visitor
In Properties, go to Color Scheme (Edit); Under Schemes select Catagory: Rooms Then under that select Department; IF you have previously set your room colors they will appear and you can apply at this point. If you have not set room color(s) then find the answer to setting colors and come back here or set them up now in the last window that shows as "Scheme Definitions" the last window you just opened in Department Legend " By Value and Department". Breath before you act.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
