Room calculation point
arkitek2ss
Message 1 of 13
arkitek2ss
How do I get the room calculation point working?  cant change/modify the grips.
Replies (12)
Message 2 of 13
Working how?  It's extents/location? Open the Family and reposition it.
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-7CA9496D-205E-4838-A669-37C1DA7DEB67
Message 3 of 13
arkitek2ss
i want to keep the door sing but change the calculation point so that's exterior of the door.
Message 4 of 13
I'm still unclear.  To Room and From Room are what is reported. Not swing side of Door.
Message 5 of 13
arkitek2ss
Yes.  To Room and From Room but change room WITHOUT changing to door swing.
Message 6 of 13
Open Family, select the RCP and press the Spacebar.
Message 7 of 13
I strongly advise against tuning on Room Calculation point for doors.  If you do that, every time you change the door swing it changes the room.  We change Room From and Room To via schedule, not via door swing direction.
Message 8 of 13
arkitek2ss
Then how would you calculate this door?
Message 9 of 13
That door doesn't need its room calculation point to be turned on and it should still recognize room to and room from.
Message 10 of 13
GaryOrrMBI
What @ToanDN means (I believe) is this:
If you have either the From: Room or the To: Room in your schedule you can swap out the associated rooms via the pulldown in the schedule.
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 11 of 13
arkitek2ss
OK.  how do I do this, wanting to keep the door swing OUT and keep the door associated with AV Studio?
If I change to the TO, it also changes the swing.
Message 12 of 13
Turn Off Room Calculation point in the door family.
Message 13 of 13
GaryOrrMBI
Did you turn off the room calculation point in the family as @ToanDN has mentioned a couple of times?
With Room Calculation point turned on in a door or window family the to/from rooms are tied to which way the swing is flipped.
With room calculation point turned off in a door or window family the to/from room is independent of the swing and can be exchanged without altering the door swing.
Gary J. Orr
