Room bounding
Room bounding
yes_and_no
Room bounding
yes_and_no
Our typical way to have bedroom area to include closet area is making the wall between them not room bounding. That s not always convenient depends on the room shape.
Now looking at the closet door,
I wonder if we can somehow making this door to be non room bounding instead. I tried, either made the default wall inside the door family non bounding or the void non bounding, still not working.
Anyone ?
HVAC-Novice
Create a section view to see where the room is stopped. Maybe a soffit or similar prevents the room from spreading into the closet. Maybe someone placed a room or space separator?
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Room Separation Line in lieu of Room Bounding Wall:
- keep the closet wall room bounding
- edit the closet wall profile and add a 'hole' the same width as the closet door at the base of the wall.  it can be lower than to closet door.
yes_and_no
Did you suggest adding this cut inside the closet door family or on the project file ?
I m looking for an automated solution, something perhaps comes from the door family settings.
In project, not family.  A door has no room bounding properties, it comes from the wall.
There maybe different ways that what I suggested, but none are automated.
vitorbortoncello
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-241430FC-8084-43A1-AA3A-681B2883B0FC
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
