Have a Revit LT file which had rooms identified and "areaed" (i.e. room area is calculated) correctly with the room labels inside the rooms.
Made small changes like adding a couple of walls.
Now the rooms are still "area-ed" correctly, but the labels will not stay inside the room, but rather go and stick to one of the walls. Clicking on the label does NOT show the opposite walls as part of the room.
Checked all the walls, they are all "room bounding".
The question is more, what is the process of debugging this?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
have you try to cut a section and check if the new walls are touching the floor finish level, base offset is 0,0? or add room separator lines? thanks
When you add a wall dividing a Room then the Room will reside on one side of that new wall, the other side has no Room, empty. So, you need two Rooms then you place another Room in that empty space.
A Room Tag can be dragged to anywhere you like inside its Room, or outside with a leader.
Are you maybe talking about this fluke that happens with the Interior Fill?
If so, uncheck Room Bounding for Wall.
That was my first check: that perhaps I had changed the base offset somehow. Sadly not the case.
Sadly the issue is not this simple. Also, it's not that the room tag is on a wall, which could be fixed with a leader. The issue is that the "room" itself seems to be just the wall not the area between 4 walls, so to speak. However, strangely, the calculated area IS exactly right, and if I delete the Room and redo it, I can see Revit showing the "big X" across all 4 walls initially, but then it posts the tag to the wall again.
I am sure it is something silly and newbie, but wish there was a debug process.
Even better if you can select the bounding walls, room and tag >> Copy to clipboard, past in an empty model and upload that here (most probably when you do that the room and tag will look fine in the empty model)
Here's what I am complaining about:
Room 72 is the issue. The left wall of this room IS room-bounding. If I Select Host, I get this:
Note the "+" in the middle of the room! With infill and reference selected, you can see room 12 is infill colored, but room 72 only has the three walls colored.
You can see that that left wall is room-bounding below:
I do have phases, but checked that all walls are in the same phase.
Wanted to see the properties palette when you used select host.. nonetheless, considering that the Reference cross lines of the room and the bleeding blue infill of the room at the borders is for sure unusual and may be caused by several things...sorry I have to ask since you cannot share a model to look at
You hit the nail on the head! As expected, a newbie issue that you pointed out: there IS a floor at 1" and it IS room-bounding:
All I had to do was uncheck the Room-bounding for the floor and everything fell in place!
THANK YOU SO MUCH!
It is not a newbie mistake...it is quite common that even experts fall into that error/mistake when hosting rooms to structural level...
But you are welcome
glad that helped
