- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a single ceiling plan sheet in this set that I've been trying to room tag, however upon checking the room tags, the rooms aren't there, even though they can be found on the regular floor plan. I've tried adding the rooms individually using the room tool option, but they don't follow the wall edges and simply appear as a small rectangle. I checked the view template, and this only happens on this specific sheet. All the other ceiling plans have the room areas show up. What could be the issue here>
