Room Area
Room Area
dm0144
Message 1 of 15
Room Area
dm0144
Hello everyone
Is it possible to calculate the area of the room where do door insert is, and not just till the face of the wall (plus the blue outline in the screenshot)?
The uncalculated area is significant when door repeats many times, such as in a large or tall building.
Any solution?
Replies (14)
Message 2 of 15
You would need to set the wall to not boundinh room and draw room separation lines manually. Or split the wall at the opening, fill the opening with another wall the same thickness of an the door, and insert the door in that thin wall.
Message 3 of 15
dm0144
@ToanDN that is soo manual work for a BIM tool.. pitty.
Message 4 of 15
You can try rentable Area plan and use Areas instead of Rooms.
Message 5 of 15
No manual work or rework here if it is modeled the way it will be built.
Message 6 of 15
dm0144
@barthbradley and how did you model it exactly?
Message 7 of 15
Message 8 of 15
dm0144
@barthbradley the wall above the door opening is usually thich as the surrounding wall. The way you modeled it, it's not correct, at least not desirable in most cases. It looks correct only in floor plan view.
Maybe, one could go further and model the wall above the door as additional piece, but that is such a manual and tedious work for a BIM tool.
(attached sketch for better understanding)
Message 9 of 15
RDAOU
@dm0144
  1. Either host the door in a stacked wall. It is not that tedious when you kick off your model knowing that you will need the areas to cover the door footprint
  2. Or use area plans instead of rooms
  3. Or simply keep the NET area calculations in schedules rather than Tags
Message 10 of 15
Actually, it is correct, and “desirability” has nothing to do with it. But thank you for trying to school me, young man.
Your question was about how to “calculate the AREA of the room where [the] door insert is” – not how to calculate the VOLUME.
Message 11 of 15
dm0144
@RDAOU Yes, it's doable but, I really hoped that it would be possible to check one parameter within the door that would consider the additional area, just like a competitive software like Archicad.
@barthbradley I have no interest in schooling you, old man.
Message 12 of 15
RDAOU
@dm0144
But then they gave you "area" plans, use them as per 2nd GIF in previous reply!! those were single walls with inserts
Message 13 of 15
dm0144
@RDAOU
In the second GIF, which instance parameter did you change from 250 to 50? How did the area boundary line recognized the door inserts by default? Are the doors hosted to stacked wall or is it a modification in the door family?
Message 14 of 15
RDAOU
@dm0144
It is the parameter that controls the wall closure from the insert family.
It doesn't make a difference where you host it, basic or stacked works the same. In the latter you would select the lower/bottom section as the primary host.
Message 15 of 15
kadmonkee
try the settings in your Area and Volume Computations menu select the option that gets the result you want
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
