Roof Visibility
Roof Visibility
gmbeloin
Message 1 of 14
Roof Visibility
gmbeloin
Hello Revit Community.
I have a question about roof visibility:
I have set up an overall roof plan using Revit 2016, and all looks good, except for the fact that the roof line and the tops of the exterior walls are all defaulting to halftone. It would be preferable to have these lines read as dark. I have tried changing the view range, depth clipping, underlay, visibility graphics, etc. Nothing will change those lines from halftone. Help!
Replies (13)
Message 2 of 14
Did you check the Phasing?
Message 3 of 14
gmbeloin
Just checked the graphics for phasing and the only thing that should be half toned is existing construction, which there isn't any of in this model. All elements drawn are in the new construction phase and the phase filter is set to show that.
Message 4 of 14
1. Make sure the View's cut plane is above the roof and the View is a Floor Plan, not a Ceiling Plan.
2. Make sure View's Display Model = Normal, not Halftone (but that would affect everything, not just Roofs and Exterior Walls)
Message 5 of 14
gmbeloin
Went through and checked those things. Cut plane is above the roof, tried messing with the bottom and view depth to bring it above the roof and then way below, but all it ended up grabbing was section heads from lower in the model and did nothing to change the halftone.
Message 6 of 14
FGPerraudin
Have you tried simply changing the VG settings for Lines > <beyond> ?
Have you checked there is not element override?
V/G overrides?
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 7 of 14
What is the View's Discipline?
Message 8 of 14
gmbeloin
I did mess around with all of those properties. The first thing I did was try to do a visibility graphics override for just one of the selected elements, through the V/G menu and then through right clicking to do override graphics in view, and the halftone would not change. Other than that, there were no existing overrides causing it to not change.
Message 9 of 14
gmbeloin
The discipline is architectural.
Message 10 of 14
If you duplicate the View, does the new View have the same problem?
Message 11 of 14
gmbeloin
Duplicated the view, took off the V/G template, STILL halftone.
Message 12 of 14
gmbeloin
Here is what it ended up being. The silhouette was set to <Beyond> in the the graphic display options, so for the heck of it I set it to our 01 line style, and BAM, halftone gone. Thank you so much for all of your help!
Message 13 of 14
Are you sure its a halftone? have you checked its line setting at VG, Material & Object Styles?
Message 14 of 14
gmbeloin
Roof VG.JPGI checked all of that. I ended up solving it though. It was through the Graphic Display Options. For some reason having the Silhouettes set to <Beyond> made it halftone, so for the heck of it I changed it to our 01 line style and it finally got rid of the halftone.
