roof vent
roof vent
asif.shamim
roof vent
asif.shamim
Hello Everyone!
 I am working on project where i have to integrate ventilation into the roof in order to reduce thermal needs of the building.
i modelled the building and then i put roof vents on top of the roof. i dont know if thats the right way of doing it. i have to do energy analysis of the model in openstudio i dont think gbxml file will export the vents along with roof too.
can someone help me please.
Roof vents have no impact on energy analysis.
asif.shamim
ok. in the task its mentioned that integrate air ventilations into building roof in order to reduce thermal needs of the building. how can i elaborate the reduction in thermal needs of building after roof ventilation?
Shouldn't your energy analysis program have check boxes to check this stuff for it to calculate?
asif.shamim
i am using openstudio for energy analysis. it exports the material that element is made of. in case of roof, the roof vent is on top of it. in simple words, when i select roof, only roof is highlighted and vents are left behind. that means vents are not part of roof. so gbxml file wont be able to read it.
RDAOU
@asif.shamim
This is not really a Revit question...you need to refer to OpenStudio and Energy Plus user documentation
A Roof Vent is an insert (ie: the roof is exported with an opening). Literally speaking Openings are holes in the roof that allow air through => Technically speaking, they do not really have any significant thermal properties (ie: no heat transfer properties). Their impact on the energy analysis is
  1. either considered as an increased infiltration/ventilation in the attic thermal zone/volume
  2. or simulated as Wind and Stack Open Area
If such vents also have covers ... then they would also be taken into consideration under the Building Envelop calculations a part of the skylights/roof ratio.
