Roof spliced in pieces
wagurto
Message 1 of 10
wagurto
Is there anyway to do this in revit? I need to produce a shop drawing desassembling a roof in pieces.
please adivice
thanks
Wil
Replies (9)
Message 2 of 10
Sure. You could use and divide parts.
Message 3 of 10
Corsten.Au
Hello
You can use two tools in Modify ribbon in Revit.
1. Parts - To create different parts of the roof.
2. Assembly - To create drawings and sheets.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Parts and AssemblyParts and Assembly
Corsten
Building Designer
Message 4 of 10
wagurto
Thank you guys. This tool is fantastic and just what i need to produce shop drawings. However, I still have a question for you. When I placed the different views on a sheet I noticed that the plan view is not exactly the real dimension of the roof part but the plan projection of the roof piece. Is there anyway I can get the real dimension of the roof piece and not its plan projection of that piece?
Message 5 of 10
Yes. Go to an assembly section view and cut another section parallel to the roof plane.
Message 6 of 10
wagurto
Thank you, really smart answer!
Message 7 of 10
wagurto
Guys one more question regarding this issue.
Is there anyway to separate the roof in slabs when converting in parts? I converted a hip roof to parts but the whole roof remains on part. I would like to have each triangle to be its own part.
thanks
Will
Message 8 of 10
You just need to slice the part to smaller parts.
Message 9 of 10
wagurto
I don't understand how to do this simple cutting.
Any body?
Message 10 of 10
