roof hatch pattern does not show on elevation?
615148142
Message 1 of 25
615148142
hi i wonder why the roof hatch pattern is not showing on elevation?  But it is showing in plan view.
Please see the attached file.  The roof pattern is showing on the plan views . But the hatch is not showing on North Elevation - Demolition.
Can anyone help me?  Thank you very much!
Replies (24)
Message 2 of 25
Check if phase graphic overrides turning off surface patterns of elements under previous phases.
Message 3 of 25
You won't see a surface pattern on the side edge in Elevation.  If you want a surface pattern on the side edge, use the Paint Tool and paint the material onto the edge surface.
Message 4 of 25
BTW: you won't even even be able to distinguish a 300mm line spacing in a typical Building Elevation.  You would need an extreme close-up to see that detail.
Message 5 of 25
615148142
I checked the phases etc and it is fine. and the pattern shows perfectly in plan views. maybe it's because the slope is too shallow?  it is only 2 degrees.
Message 6 of 25
615148142
Thank you!  I am talking about the roof, not the side of the wall.
Message 7 of 25
Okay that's why.  The pattern is too dense so Revit omits it.
It will show if your view has a bigger scale or you turn Thin lines off.
Message 8 of 25
615148142
I think the scale is fine.  the scale shows fine on plan views
Message 9 of 25
615148142
But why the pattern shows fine in plan views?
Message 10 of 25
Look again.  That is your Roof I'm showing in my Screenshot above.
Message 11 of 25
615148142
but i need the roof patterns to show at 1:100 and not have thin lines off.  How can i do that?
Message 12 of 25
I thought you wanted the edge of the roof to have the same surface pattern as the Roof. If so, PAINT the edge with the Material.
Message 13 of 25
615148142
the roof itself is not showing the pattern on elevation, please see the attached image,
Message 14 of 25
Message 15 of 25
615148142
I can see you painted the edge of the roof.  but I don't need the edge of the roof to show pattern.  The roof itself is not showing the pattern,
Message 16 of 25
615148142
I tried to paint the roof, but the pattern line does not show up.  I think it's because the slope is too shallow?  it is 2 degrees
Message 17 of 25
615148142
when I turn off "thin lines" button, the pattern shows up.  but we turn this button on, the pattern line dissappears.  strange.  I need the pattern line to show with "thin lines" button on
Message 18 of 25
615148142
I tried to paint the roof, but the pattern line does not show up.  I think it's because the slope is too shallow?  it is 2 degreesI tried to paint the roof, but the pattern line does not show up.  I think it's because the slope is too shallow?  it is 2 degrees
Message 19 of 25
615148142
Message 20 of 25
