Roof Errors
Roof Errors
KraiggC
Message 1 of 33
Roof Errors
KraiggC
I'm working in Revit 2018.3. I don't understand my issue in the slightest. I tried creating a roof, from foot print, and I kept deleting lines til it would create. I literally can not get a roof to create with more than 6 sides. Is there something wrong with build of Revit? I've attached a snippet of a roof shape that errors out.
Replies (32)
Message 21 of 33
@SteveKStafford wrote
I don't see how simple it would be to deal with a roof like this with shape editing, no matter how much I like to use the feature.
I don't no what to say to that. Took me less than a minute to draw the roof above.  2 Split Line representing 2 (of the 4) ridges.  The offset value of the ridge is equal to the total rise at that location.  For example, if it's a 5:12 roof and the ridge is inset 15 feet from the roof's zero origin, then the ridge is elevated 6'-3".
Cheers!
Message 22 of 33
@KraiggC: Is this latest roof actually modeled? It make no sense to me. Can you show us a 3D view of it?
Message 23 of 33
KraiggC
Is it possible to build a gable that dies into the sloped side of a hip roof into one roof? I know I can build the hip, then the gable separately but Id prefer not to do that due to the gable end being in the same plane as the eve of the main roof. But if it can't be done then I guess I won't have another choice.
Message 24 of 33
KraiggC
Yes sir, it's finally getting modeled. My problem seemed to be originating from the fact I picked lines instead of manually drawing them? Then I had some other issues with my roof not allow me to make it square in the "L" sections, but that was relieved by offsetting the line instead of drawing is and adjusting it via the temporary dimension.
Message 25 of 33
SteveKStafford
If you mean a gable like this (images)? Edit the boundary of the roof sketch so that there is a segment for each half of the gable, either side of where the gable ridge would be and then place a Slope Arrow on each, pointing toward the ridge. Change the slope settings for the slope arrow as needed.
Steve Stafford
Message 26 of 33
Reminds me of Penrose Stairs. Ha!  Want to post it?  Still can't make sense of it from the 3D screenshot.
Thanks.
Message 27 of 33
KraiggC
No, as you can see from the latest image I attached I have gables already. The situation I have is a gable located in a valley that has one side dying into a hipped slope.
Message 28 of 33
KraiggC
Haha yea it got pretty complicated. There are still about 10 or so gable I'm working in as well.
Message 29 of 33
Ah! I see how it works.  Nice.  I can see the rest of the roofs being done as separates and joined via the Roof Unjoin/Join Tool  on the Modify Tab.  I don't see a condition where a gable would dive into a valley, as you described above.  Maybe you can post a screenshot with circles around the areas you are finding challenging to roof?
Message 30 of 33
KraiggC
It's not modeled yet, but attached is a screen shot with the area in question.
Message 31 of 33
Why not just move the hip out of the way?
Message 32 of 33
KraiggC
The floor plan, and resulting roof design, kinda dictate the gable location. i tried nixing it altogether. that wasn't well received.
Message 33 of 33
it's a weird condition. I don't how it frames.  But you can get there in Revit (sort of) with a Roof by Extrusion.
