ROOF BY FACE TOOL NOT PICKING/HIGHLIGHTING MASS
careyokumbe
Message 1 of 18
careyokumbe
Hello so this issue is quite annoying.  I created a curved form through mass so that i can make a  complex curved roof using the roof by face tool . It worked multiple times before but when i had to delete the mass in order to make a better roof the roof by face arrow or picker wouldn't highlight the mass at all. The picker works for the wall and topo solid. The mass has a simple geometry i just wonder why it wouldn't pick it this time round yet previous masses were more complexspline through pointsspline through pointsThe created form cannot be picked by the roof by faceThe created form cannot be picked by the roof by face
Replies (17)
Message 2 of 18
hmunsell
when I tried this, it had to do with how the end conditions were lined up.
if they were off, it wouldn't work.
basically the same shape, but when those end condition's weren't in line, it wouldn't make the roof.  i could make it a Wall or Curtain System, but not a Roof.
Howard Munsell
Message 3 of 18
You said you could create a wall by face with that shape then do it.
Message 4 of 18
hmunsell
I already deleted the file.....
I'll remake it though, just for you 😁.
Howard Munsell
Message 5 of 18
hmunsell
Here it is as a Wall by Face.
Howard Munsell
Message 6 of 18
hmunsell
@ToanDN I didn't see you were replying to @careyokumbe, not me... sorry, my bad 😂 🤣 ....
Howard Munsell
Message 7 of 18
careyokumbe
hello thanks for this but problem with a wall is you cant really attach a wall to it or maybe i just dunno how to attach a wall to a wall in revit
Message 8 of 18
careyokumbe
I cant just wing it... i thought maybe there are principles to follow with the spline through points... yet i dunno what worked for me then
Message 9 of 18
careyokumbe
These are ordinary splines... how can you change the heights of those  end points
Message 10 of 18
hmunsell
In my simplified version, I just went into an elevation and adjusted them the spline. I assuming you made a series of splines and then selected them to make a solid form. If you make a Reference Plane or Section parallel to each spline,
you can use the Orient to View or Orient to Plane tools to set your view as needed.
The more fluid forms like that do seem to be finicky though. In my second example I had to remake the mass face and I couldn't get a roof to place. It would let me select it, but I got an error when it tried to make it. I'm sure if I played with it some I cold have gotten it to work.
What is the end product? Is that going to be a solid Roof, a Membrane, Glass, ...?
Howard Munsell
Message 11 of 18
careyokumbe
In instances where the roof by face can highlight the roof but brings an error of can't make roof,  i earlier realized that it can work when you go to the picked faces location and choose switch the roof facing bottom rather than top at the properties panel
Message 12 of 18
careyokumbe
lemme try and see if i can change the end points to align
Message 13 of 18
careyokumbe
Its supposed to be a solid roof
Message 14 of 18
Good point.  Can you share the mass?
Message 15 of 18
careyokumbe
yes please how do i do that
Message 16 of 18
Attach it to your post.
Message 17 of 18
careyokumbe
can i send via google drive the file is too large
Message 18 of 18
Yes.
