Ridges using fascia tool. How to clean up.
stuart
Message 1 of 11
stuart
Hi All,
I am using REVIT LT and while I am sure in place mass modelling could sort this in FULL revit.
I am wondering if anyone has managed to clean up the ridges when using the fascia tool? Is there another way to achieve my goal?
See the attached images.
Replies (10)
Message 2 of 11
Does LT have Beams?
...are you using fascia tool for valley flashing. Kind of looks that way in your second screenshot. The fascia in the first screenshot should be easily corrected though.  That's done using Fascia tool; right?
Message 3 of 11
stuart
It does have beams.
These are hipped roofs.
Normally it would clean up, but because there are two different angles at play 15 deg and 37.5 deg it's creating this ugly issue.
Message 4 of 11
Can you share the file please?
Message 5 of 11
stuart
Hi There,
Model attached.
Message 6 of 11
Here's my solution:
In-Place Modeled Void cuts clone Roof Type.
Message 7 of 11
For a cleaner, create another thin roof with the exact footprint (copy), then use vertical opening cut to cut to the ridge footprint.
Message 8 of 11
That's pretty much what I did above.
Message 9 of 11
stuart
Thanks for this.
Message 10 of 11
stuart
Thanks for this way. I can do that with REVIT LT.
Message 11 of 11
@stuart wrote:
Thanks for this.
Glad my solution worked for you.  Pretty nifty, huh?
