Ribbon panels tab shows drop down
Dear Revit Users,
While using Autodesk Revit 2014, I've come across the problem with Ribbons.
Please find the attached pictures for more details.
My ribbon is showing in a drop down format (Pic1.jpeg) instead of the tabs showing in the quickview (Pic2.jpeg)
What I see is below mentioned snapshot (pic1.jpeg)
What i finally want to achieve is as the below snapshot (Pic2.jpeg)
I'm very new to this site as well as to the Revit 2014. Please someone solve my problem
L.Maas
Use this button
Louis
Please mention Revit version, especially when uploading Revit files.
Mr. Louis,
I've tried that as well. But still the problem pertains. How do I sort out even after this?
Thanks for the reply sir.
Siddharth
L.Maas
You also clicked this button?
Is this the only issue you experience with the interface?
Otherwise you could try to reset the user interface and see if that solves the problem
You can have a look at THIS article on the Autodesk Knowledge website.
It renames a key in the registry whereby the graphics interface is reset (e.g menus).
After restarting Revit this key in the registry will be rebuild.
See if that helps.
Otherwise look for updates.
If it is a recent phenomenon you also could try to go to a recent restorepoint.
Louis
See if that helps.
Thank you, Louis. It worked like charm.
