Revit2026 query
Revit2026 query
adrian_bada1
Message 1 of 10
Revit2026 query
adrian_bada1
I've been using Revit2026 so tonight, I decided to uninstall Revit2024 and Revit2025 but suddenly, I can't open Revit2026. I thought I just had some residual files that I missed from 24 and 25 so I did a sweep and uninstalled everything with Revit2024 and 2025 in the name, I also uninstalled 2026 and reinstalled it but it still won't open.
I'm in the middle of an assignment so I'm panicking. I thought I'd ask a quick question cuz I've tried everything I could but still can't fix it. Any ideas? Thanks in advance.
-Adrian
Replies (9)
Message 2 of 10
arq_42
Are you seeing any kind of error message?
Could you take a screenshot or screencast so I can see it?
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
Message 3 of 10
TripleM-Dev.net
Are you double clicking on the project file or first trying to open Revit?
And as @arq_42 , any messages or it just doesn't display anything?
Also look into process monitor, is Revit process running then force close it.
Any windows updates pending?
What OS, Windows 11?
- Michel
Message 4 of 10
adrian_bada1
No errors, it's just stuck on the little "initialising window". I left it loading last night before I went to sleep and it's still loading now.
Message 5 of 10
adrian_bada1
it's been stuck on this since last night
Message 6 of 10
Basam.Yousif
I can help.
Rename the following folders by adding "-old" suffix:
C:\Users\{username}\AppData\Local\Autodesk,_Inc
C:\Users\{username}\AppData\Local\Autodesk\Revit\Autodesk Revit 2026
C:\Users\{username}\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2026
If no luck, then also this folder:
C:\ProgramData\Autodesk\Revit\Addins\2026
Let me know if none works.
Message 7 of 10
adrian_bada1
Thank you, I’ll try it this afternoon when I get home. Hopefully it works 😂
Message 8 of 10
adrian_bada1
Thanks so much!! It worked!!
Message 9 of 10
pnandu
Observer
Observer
Didnt work for me 😞
Message 10 of 10
Basam.Yousif
What issue are you having?
