Revit Window Family being selected outside geometry
armiin_hodzic
armiin_hodzic
 Hello, i have a problem window family is being selected from blue point, outside geometry of window, how can i fix this i have attached family file, thanks 🙂
vitorbortoncello
Everything looks ok. Both your "origin" reference planes are defining origin:
Also, i tested the family and it's working.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
armiin_hodzic
Hello, problem appears when i load the family in project.Cursor is way off the window geometry and its being selected
se.ha
Hello @armiin_hodzic
The problem seems to be, that your reference planes extend about 1.5m outside of the wall:
Unfortunately I dont know how to "shorten" them but you could always set them to "not a reference" and they will disappear in the model:
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
