Revit winder stairs parallel treads please help !
rowson101
Message 1 of 8
rowson101
Hi.
I am trying to create a 3015mm high winder stair with total of 17 risers.  However I cant achieve the desired number of parallel treads.
See photos.  I basically need all the treads to be parallel except for 6.  Which I want from a single point.
I am trying to avoid using 2 L shaped stairs because I want to number the risers 1-17.
Appreciate any help.
Current SituationCurrent Situationdesired outcomedesired outcome
Replies (7)
Message 2 of 8
You're using the wrong stair tool then. If you don't want Revit to calculate tread automatically; then sketch your stairs (e.g. user defined Boundaries & Risers).
Message 3 of 8
rowson101
Ok so Iused the stair by sketch tool.  It looks how I want it, the only problem now is the tread numbering tool wont work.
Any ideas?
Message 4 of 8
The tread numbering tool doesn't work? How so?
Message 5 of 8
rowson101
It works when for component stairs but not sketched
Message 6 of 8
 Are you talking about the tread number annotation tool? It doesn't work on a sketch-based stair.
Message 7 of 8
constantin.stroescu
for something like this:
have a look to my rough screencast:
Constantin Stroescu
Message 8 of 8
Don't use stair by sketch.  Use stair by components then convert to sketch.
