Revit wall wrapping in SECTION
vw-architects
vw-architects
I know there is a way to wrap gypsum in section... I have done it before but forget. Tried to find the video I used and cannot seem to find that either. My issue is that I have a wall that comes down from the ceiling about 13". I don't want the end to be shown incorrect in section and putting masking regions will take too much time. If someone can give me some advice I would appreciate it. I have attached an image as well.
constantin.stroescu
one method could be :
  • in model component: Wall > Sweep    - Wall > Properties > Edit Type > Type Properties > Construction>Structure>Edit > Modify Vertical Structure ( in Vertical section view) > Sweeps.  The Sweep Profile is made so to to fit the thickness of the wall and the thickness of the Layer
  • Other method could be a View tool : Cut Profile - a very quick method but it does not affect the model as the first method does.
Constantin Stroescu
nathaniel.mcmahon
How about for openings using the same constraints from the family object as the plan shows?
Manually place a Wall Sweep above and below the opening and grip stretch them to fit?
