Revit Wall Sweeps added to exterior walls - Included within group but not selectable.
frederikJJUCG
frederikJJUCG
I have recently added wall sweeps to several walls to include a 3" x 1/2" wall base for interior elevations. The same wall sweep has been added to several exterior walls that have no sweeps added.
The strange part is that the wall sweeps are included as part of a group but not selectable when activated.
Does anyone know why this is happening, and how that can be controlled?
Frederik
Are they added in the wall assembly or placed manually using Wall: Sweep tool?
RDAOU
@frederikJJUCG
 Maybe you had them pinned and Select Pinned Elements is disabled?
The image you posted doesn't show much ...when you edit the group they are grayed out or just not select-able?
frederikJJUCG
@ToanDN@RDAOU,
They are neither part of the wall assembly, nor placed manually. I believe the were somehow placed via a group. See images below. The group includes the sweep, but when opened they cannot be selected.
I went through and deleted the sweep out of all walls in the project, these still remained on the walls. (deleting the sweep profile just replaces the sweep on these walls with another profile).
This image shows no sweep on the wall type..
RDAOU
@frederikJJUCG
Being replaced by another profile (the default rectangular) when deleting the custom profile is a behavior of sweeps built into the wall structure.
Can you edit the group in Group editor? From the browser right click and edit?
If you open the sweep tab in the wall structure, are their any added fields? Or is it empty?
frederikJJUCG
@RDAOU
Of course, see below. What has me confused is that the walls that have these base sweeps are not part of the group or any instance of the group.
The sweeps tab is completely empty (I did a test, the sweeps tab has cleared on every wall type in the project - These still remain)
frederikJJUCG
Excluded members of groups (walls) had intersected the exterior walls making the exterior wall register a base. I cannot explain why this happened... But, by replacing the intersecting walls with walls that had no base sweep removed the base sweeps from the exterior wall.
