Revit/Twin motion problem
tony2CF5M
tony2CF5M
I just freshly formatted my working computer, installed Revit 24.3.10.22 - 20241105_1515(x64) - 2024.3.1 and Twinmotion 2024.1.2 for Revit, though when I try opening my 3D view via the Revit Twin motion tab, I get the following error!
Any idea what it could be?
azad.Nanva
  • Ensure the Twinmotion Revit plugin (Direct Link) is installed correctly and is compatible with your version of Revit and Twinmotion.
  • Visit the Twinmotion Plugins page to download the correct version for Revit 2024.
  • Ensure your GPU drivers are up-to-date. Twinmotion and Revit rely heavily on the GPU for rendering, and outdated drivers can cause conflicts.
  • In Revit, go to the Add-Ins or Twinmotion tab and verify the plugin configuration.
  • If necessary, re-link the project to Twinmotion.
  • Uninstall and reinstall the Twinmotion plugin. Be sure to restart your computer afterward to ensure proper initialization.
  • Both Revit and Twinmotion release updates that may address compatibility issues. Confirm you're using the latest versions of both.
in this case use the Revit link in Twinmotion,How?
RDAOU
@tony2CF5M
In addition to the above...see Version Compatibility below...The version of twinmotion seems to be not the right one for Revit 2024.
You also need to link your Twinmotion Account to the autodesk account (When I am loging in to Twinmotion on an account linked to a differnt ID than the one I am logged in to Revit, it gives also same error)
The following in the link to Twinmotion for Revit Installation website Autodesk - Twinmotion
tony2CF5M
Thanks for the information guys, I managed to dig further into this situation and got Twinmotion 2024.1.2 direct link working with Revit 24.3.10.22, all works perfectly fine now.
