Revit Topography
Revit Topography
KraiggC
Revit Topography
KraiggC
Can Revit export topography to FBX? I've been attempting to export a model I have with topography for about 4hrs now. I can export a model without topography in seconds, is topography just that intensive or what is going on?
virgilio_benedictos
hi @KraiggC
its seem that topography is very extensive try to split into a certain numbers of blocks. and then hide the other and just leave one block of topography try to export. if you succeed. do the same to the others.
KraiggC
Thanks.. but the issue seems to be the pads. They must be adding more polygons than the program is capable of exporting. I deleted the pads and it exported faster than I could watch the bar fill.
