Schedule - Getting Total Area Customized
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
sjiX3D8W
1661 Aufrufe, 7 Antworten
Hi.
I was wondering if I can get the Total Area of certain conditions only.
I assigned departments and got the total areas for each department.
but I want to exclude 1 department in total area.
If you see the image attached, I want to exclude blue (but want to show it in the schedule).
I want to add the yellows and show them as total area.
Is there any way that I can calculate the areas in certain conditions? (maybe if function??)
Does anyone have any idea??
Thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: sjiX3D8W
Why don't you FILTER that Department out of Schedule then?
Nachricht 3 von 8
bin
probably not.
Maybe you need to create 2 separate schedules with filters and place them together.
Nachricht 4 von 8
sjiX3D8W
als Antwort auf: barthbradley
I am comparing several options and one has outdoor circulation.
I want to show the size of the corridor even though they are outside circulation.
But I don't want to include that into total, because it is not an enclosed space.
What I did for now is creating 2 separate schedules and placed it next to each other.
Out of curiosity, I was wondering if there is any smarter way to do this...
Nachricht 5 von 8
Include the outdoor area in the Schedule and create a Calculated Parameter Area Column (e.g. "Area 2") to total just the inside Areas.  The Calculate Parameter would use a formula to carry over all the inside Areas, and not carry over the outside Areas.  For example =if([Outside Area], 0, Area) --- where [Outside Area] is some identifier such as Mark or Comment.  That make sense?
Nachricht 6 von 8
sjiX3D8W
I tried something and got an error... Could you see and tell me if this was what you meant?
Thanks!
Nachricht 7 von 8
Conditional statements can only evaluate numeric values, numeric parameter names, and Yes/No parameters.  You could create a Yes/No Project Parameter for each Area, and then the Calculated Parameter "Area2 - indoor only" if statement could be =if([Yes/No], 0, Area)  -- where [Yes/No] is the Project Parameter and the checkbox status  is checked.
Nachricht 8 von 8
sjiX3D8W
Thanks! it worked!!
