REVIT TOPOGRAPHY
REVIT TOPOGRAPHY
ngurearchitect
REVIT TOPOGRAPHY
ngurearchitect
Hello guys,
I was sent a project where a section of topography is missing in 3D but cutting a section across that area reveals that the topography is still there. What can I do to show it in 3D?
I have tried to split the topography and create a sub region but once it gets to this section it disappears.
se.ha
Hi @ngurearchitect,
looks like in 3D there is the section box activated. You can change its size or deactivate it (3D-View Properties -> Section Box)
Video: Use a Section Box | Revit 2020 | Autodesk Knowledge Network
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
ngurearchitect
Thanks turns out I was just blind
