Revit - PDF / Crop Region Printing Error
4 ANTWORTEN 4
Nachricht 1 von 5
KameronNWYMM
404 Aufrufe, 4 Antworten
This is for Revit 2023
For some reason when printing to Bluebeam pdf (adobe never works) I have recently been having an error where the first sheet with a crop region (the actual first sheet is project information sheet with legends and text groups only), that view's crop region is being applied to all remaining sheets. Also, the following sheet's title blocks are not printing after the initial sheet either.  See images below. I have the pdf set and a screenshot of what the sheets should look like. (I was able to print last week just fine with no issues)
This is happening consistently whether I swap the order of the sheets or not. Even when not combining the sheets into a single pdf, this is still happening.
Any thought's on how to remedy the situation? Everything looks fine when I check in the print preview page within Revit itself.
Beschriftungen (4)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: KameronNWYMM
I have not used Revit 2023 for production yet so I can't suggest anything, but have you tried the Revit's Export to PDF instead of of printing?
Nachricht 3 von 5
KameronNWYMM
als Antwort auf: ToanDN
Yes, doing the export is printing, but it looks like I'm having some scaling issues ( I can resolve this on my own). I can use this as a workaround for now but I still don't understand why the regular print option isn't working...
Nachricht 4 von 5
What scaling issue?  What are your PDF Export settings?
Nachricht 5 von 5
KameronNWYMM
Thanks for this response. This has solved the export issue. I never had used this form of printing in the past.
I will continue to use the exporting for printing option. However, I am still confused by error that is continuing to occur per the original post.
Thanks again for helping with a workaround for the time being.
Cheers,
