Revit Topography
Revit Topography
Revit Topography
HI, can someone please help.
When I place points for my topography and then view it in 3D/a side view, it does not show me the incline. It stays a flat surface like all my pionts are 0 instead of a range between 0 and 20 meters.
How can I fix this? I am used to working with Model Maker, so Revit is a whole other game for me.
aleksei.tkachenko
Hello
See my screen cast that shows how you work with toposurface.
http://autode.sk/2uCdo5v
hello dear,
make sure that you are assigning the points height before placing them ,
i advice to add the points in the top view as well .
i did not work ,, add a screen shot so we can clearly understand what is the issue 🙂
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!Smiley Happy
Please see the information HERE on how to create a toposurface by placing points.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
