Revit Topo - controlling contour lines
I have labeled contour line 1137' which shows up as a primary contour, whereas I would like 1135' to be one of the primary contour lines.
So basically I want to adjust which elevations are the primary contours. Is this possible?
Open the dialogue Site Settings (opened by pressing the arrow in lower-right corner of Massing Site under Massing & Site Tab).
Ive looked in that box and changed #s high and low but don't seem to be able to get what I'm looking for.
Change "Passing Through Elevation" to -2' or +3' see what happens.
FGPerraudin
Check your Start and stop interval includes your site heights as well.
Françoisl
Sorry - ignore it I hadn't seen your screenshots
Francois-Gabriel Perraudin
BIM management and coaching
