Revit to .NWC - Parameter/Property Order Display
Luke.ODriscoll
Luke.ODriscoll
Hi everyone,
I've exported my Revit model to Navisworks, however, the type parameters display in Navis in no logical order whatsoever. Is there a way to reorganise these properties within Revit?
Originally I exported under the impression that it would display under the parameter groups I set in Revit, to no avail. Then I recreated the parameters in alphanumeric by adding a number prefix but it still won't display in order. Am I missing a setting, or is this just an information loss between formats that has no solution?
SteveKStafford
I've wondered about that myself. I think it has to do with what the properties names are behind the scenes. There is a setting in Options editor > Interface > Developer with two options: Show Internal Properties and Show Internal Property Names. When those are turned on we can see the underlying names and numbers associated with each property. I think those are affecting the sort order we see, not the "name". Lacking any better info I moved on...
Steve Stafford
