Revit to Navisworks only Levels & grids show up! Help!
SBrownHK35H
SBrownHK35H
I am trying to run a clash detection in Navisworks but I cannot get my Revit model to load properly into Navisworks. I have the 3D view correctly in there but none of the elements are being brought in. I have MEP/FP items in the Revit model that are not bring brought into Navisworks.
Please help!
Basam.Yousif
Are you on the latest version\build of Navisworks?
Navis is similar to AutoCAD - meaning you can use ANY version, unlike Revit.
SBrownHK35H
I am using Navisworks 2022 & Revit 2022.
Basam.Yousif
Are you exporting NWCs out of Revit? or reading the model directly into Navis?
Can you test Navis 2026?
