Revit to MAX whitepaper or tutorial
2 REPLIES 2
jwellman
453 Views, 2 Replies
jwellman
A while back I thought I ran across a whitepaper or tutorial / best practices on getting a REVIT model into MAX, via FBX file.  Can anyone point me in the right direction?
2 REPLIES 2
kathryn.langan
in reply to: jwellman
kathryn.langan
Here are some resources you might want to take a look at:
The Revit Clinic: Revit 2011 FBX to 3ds Max 2011 Tips
Autodesk YouTube Channel: FBX File Link with Revit Architecture
Autodesk University Online Classes: http://au.autodesk.com. A search of the online classes will result in many videos and white papers, including Preserving AutoCAD Revit BIM Information in Autodesk 3ds Max Design, Autodesk 3ds Max Design for Revit Users, Revit to 3ds Max via Autodesk FBX...
I hope this helps get you started!
Katie Langan
Technical Support Specialist
Customer Service & Support
Katie Langan
ryan.duell
ryan.duell
I believe the white paper is on the link below, entitled “Autodesk FBX-Based Revit Architecture 2009 to Autodesk 3ds Max Design 2009 Workflow”:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=10155245
Thank you,
Ryan Duell
Thank you,
Ryan Duell
