Revit to DWG hatch in wrong layers
yangshilun2012
yangshilun2012
Hi everyone,  I made a  generic model component. The elements of the component are in different subcategories and different materials(different surface patterns).  I found the suface patterns(hatch in CAD) are not in same layer of the outlines after it is exported to CAD, it seems that the layers of surface patterns are shifted. Is it a bug or I made some mistakes? Thank you.
What Standard are you using? AIA is what your RVT's default is when I open it.  I don't see any issues with the hatches after I export Elevation and open it in AutoCAD.
lim.wendy
Hi Shilun,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
yangshilun2012
Sorry for replying late,  I changed default exporting set, perhaps I have not saved properly. Here is my setting in attached picture. I try to export a generic componet which has some elements in different subcategories, then export to DWG in different layers. The result seems that the elements themselves are in right layers, but the material patterns(hatch) are in wrong layers.
yangshilun2012
Hi Wendy, sorry for checking late. I export again, I still meet a same problem.
