Hi, I'm has problem with the block names when I export a Revit Model to .dwg file.
When my model familys are exported to Autocad the family name in Autocad block has been should the same in Revit?
Like, my Revit Family is "Bloco 14x19x39", in the Autocad the Block Name should be the same, ok?
When I export to Autocad the block name show a ambygous number.
Pictures below.
There are some posts about that, but no solution has finded.
Pictures below.
Solved by RSomppi. Go to Solution.
Rename the Block. Command=Rename.
It's very manual. Have some one way to make this in Revit? Like, exports with this configuration
Families and blocks are not equivalent. Families have options that are not available in AutoCAD. That's why the "ambiguous" number is necessary.
The solultion is to cleanup in AutoCAD.
Correct.
