Revit to ansys ..
Revit to ansys ..
Revit to ansys ..
is that any way to get the Revit model into Ansys to use it in flow analysis for HVAC systems?
ennujozlagam
you can try to export with these file extension and see if helps. thanks
ennujozlagam
also with this. thanks
I will try it .. thank you
non of these extensions are working with Ansys...
ansys accepts files .stl or .step ...
