Revit Titleblock Background colour
courtney9JVQZ
courtney9JVQZ
i would like to add a background colour to a titleblock (cover page)
i have tried using a filled region over the full page.
but once loaded into revit, viewports or images are coming in behind the filled region and not visible.
how can i set this as a background and not a filled region?
also, is there a way to make a hidden line view appear as an invert
(to place on top of the background) so that it looks like a blueprint line drawing.
or have a white image show on the background
syman2000
Use color image as your background instead of fill region. As for inverted lines, it is pretty easy to achieve. First you want to set your lines as white and add cut and surface pattern as solid black.
