Is this a shared parameter? B/c it is you can use tags and path the label to that parameter if it is a project parameter it won't be able to be tagged
you mean the description of the door? if the values are properly inputted in the Type / Instance Parameter of the Dolor, this can be automatically done in Dynamo. So when the values change, this door schedule also changes...
Exactly. How can i put the description of the door in text, with a simple click on the door, takes it the properties , and change automatically the description (ex. Interior-Double -Full glass... ) without using copy/paste or type one by one. Dynamo 😔.
